kay8888 »
https://forums.nicoclub.com/kay8888-u211570.html
Wed Oct 31, 2012 1:09 pm
Hi Guys,
I am having some problems with the Zed and have searched quite a bit but haven't found a solution so I thought I make a post and figure it out. If there is another post somewhere of this issue, please let me know.
I recently put a rebuilt alternator in the car along with some new grounds because the previous grounds were connected to the manifolds and i was told by the mechanic that i should change them so he changed the grounds along with the alternator/starter ground.
The other day i was driving the car at night and it started running a bit rough and shortly after, the HIDs went off. High beams and fog lights are working fine. Soon, the car just stalled and died and the Anti-lock light also lit up. When i tried starting the car, it would crank once and then make ticking sounds and won't start. I kept trying and the car won't start but 5-10 minutes later it started and i quickly drove it home. When i was pulling in, the car stalled again and the ANTI-LOCK light came up again. I boosted the car and it started first time. I didn't drive the car as it was getting parked for winter anyways. I checked the codes and was getting code 34 ( when i looked at the engine bay, i saw that the det.sensor wasn't even connected from i dont even know when and never got code 34). So i connected it, cleared the codes and started the car again. Still got code 34 and now i got code 42 as well. I cleaned the connected for det.sensor and also the fuel pressure sensor and reset the codes and started the car again and same thing.
One thing i noticed was when the car is idling and i rev it, the dash lights brighten up. They don't dim down when i let go of the throttle. The HIDs are still off.
I spoke to a different mechanic and he said that there is grounding problem somewhere so I am wondering maybe the guy who did the ground with the alternator/starter and other grounds in the engine bay screwed something up?
I also searched only and saw that it may be the rebuilt alternator's voltage regulator?
When the car stalled and i started it again, i connected the meter to test voltage across the batter, when i would rev the car, the voltage would keep increasing instead of staying a specific spot.
Anybody experienced this? or could help me with this? I would really appreciate it. Car is currently parked for winter in the garage so i can open things up and look around. The car has been starting in first try ever since. Idles fine, but as soon as i rev it, the lights brighten up and the car runs a little rough.
Thanks
