BumptiousQ »
https://forums.nicoclub.com/bumptiousq-u189994.html
Tue Aug 30, 2011 9:22 pm
First time poster here. Just curious if anyone else has had an issue like the one I'm about to describe.
So my '07 Sentra 2.0S has about 72k miles on it. I bought it used with 41k, and have driven the rest over the last two years. This issue began occurring at about 68k. Here goes:
The CVT feels like it slips during light acceleration at freeway cruising speed (65 mph @ slightly under 2k rpm). I want to maintain my speed on a slight grade, for instance, so I apply a little bit more pressure to the accelerator. What happens is this: the tach climbs to ~2200rpm and the transmission reaches a point where it wants to shift; instead of engaging a lower gear, it slips and the revs drop back down under 2k. It will do this repeatedly if I keep the same pressure on the accelerator. Revs climb a bit, then drop back down, and the car loses speed. I really have to mash the pedal and rev it above 3k in order to get the transmission to engage a gear that will move the car. It happens on flat sections when I want to increase my speed just a few MPH. I've noticed that having the AC on makes the problem worse. Occasionally, the transmission slip feels a bit more violent.
Freeway driving is never smooth, and I can't stand it. It even happens on streets with speed limits above 50.
Anyway, I hope my description makes sense. Any input would be great.
Thanks.
