180fan wrote:Check the fuel pressure. Then onto the fuel pump, with the key in the last position before it actually starts. Do you hear the fuel pump whirl up? Next check over your spark plugs. What's the tip looking like?
Im not exactly sure how to check the fuel pressure.
Although I did listen for the fuel pump and it sounded ok.
I just replaced the spark plugs like 3 months ago so Im not sure if they would be bad already but I'll check those next.
