Strange Clutch Issue
aroche25
Car: 2007 Mazdaspeed 3 GT
Looking for a Z32 Slicktop
I am experiencing a very hard clutch pedal and slipping. This happens only after it has been pumped a few times(you can feel the pedal get harder after every press) and goes away after you let it sit for a short time whether driving or sitting. While the pedal is stiff there is no free play at all and the clutch engages/disengages with almost no travel. The problem started a week or so after I did a proper height and pedal adjustment and bleed/swapped fluids over to Motul RBF600. The fluid looked original and horrible when I bleed and swapped it over. The clutch felt perfect for a few days then this issue started, I got around it 2 days ago by readjusting the pedal but now I have the problem again.
Any suggestions or other tests I should run?
Thanks!
verge513
Car: 95 240sx
you sure all the air is out? loose fitting somewhere?
aroche25
I went through almost 3 pints of fluid when I was bleeding, and rotated between the upper and lower bleed points. So I doubt there's air, but Ill try it again if other people think there's air in the system as well.
verge513
Car: 95 240sx
thats the only reasonable thought for the clutch slipping if the clutch was good before the fluid change..did you have a second person with you during the bleeding? did you pump up the clutch and hold it down then have someone open the bleeders?
aroche25
Yeah the clutch slips when the pedal is hard but is perfect when the pedal feel is normal. Yep I did exactly that and I had a 3rd person constantly topping off the reservoir.
verge513
Car: 95 240sx
but no problems before fluid change? double check ur slave cylender. for binding..if you have alot of time (not a dd) you could always leave the res. cap off to allow trapped air out..these systems can be a big pita to get air out
mrmoose
Car: 91 300zxtt
new clutch time... either one of the components is worn out or the clutch and pressure plate need replacing. i had the same problem.
verge513
Car: 95 240sx
or that but if it was fine before the fluid change then maybe not..but if u do change out the clutch...change out every part pressure plate, disc, throw out bearing,pilot bushing, and maybe fork depending
aroche25
mrmoose wrote:new clutch time... either one of the components is worn out or the clutch and pressure plate need replacing. i had the same problem.
What is the best clutch to go with?
NolimitZ32
depends on what you want, generally DXD/Shouthbend has the best bang for your buck unless you want a carbonics 5 plate or something. Also ive never used the SZ clutch but I'd imagine its a great set (made by RPS)
