Strange clicking/ticking/squeek
vannaksao
Car: 2003 Nissan Pathfinder SE, 1997 Mitsubishi Eclipse GSX
Can't figure out what it is. Replaced the idler pulley (alternator side), even though this didn't fix the problem, the pathy runs much much smoother, quieter, and has a much healthier idle.
I held a screw driver to my ear, and then to most of the components to try and find that squeek. I don't know how to describe it, it's like the sound of fast squeek- kinda like when you hear basketball shoes scuffing on the court. It's coming from the right side (if you're sitting in the car looking forward), on the alternator side.
1. My belts are new
2. replaced idler pulley on alt side. (Did not re-install the dust cover)
Maybe I should check the crank pulleys? Alternator Pulley?
I've attached the video, you can hear the sound...
http://www.flickr.com/photos/56891815@N04/5249891796/
ARKQX33V6
Vid moves around too much for a sense of direction, here are my guesses!
Vacuum assisted item
Idle air
PVC blocked up
Use a stethoscope to pin point
