strange ABS
bradon123
Car: 92' 240sx se alll options woot 500$$$ good find i think
ok im not too experienced but i can wrench whith some confidence. its a 92 hachback ka24-de. took it out and the abs starts pumping but when i come to a complete stop the car stalls!!?? my friend and i think it might be the abs module.. i dont know what that is but he said that it probably failed. any thoughts??
DevilMB3017
If you don't want to use the ABS, as many people choose not to, or to find out if your car won't stall, there are three plugs that you can disconnect to disable the ABS. All three are right next to each other in the very back of the engine bay on the far left (passenger side) if you are looking at the car from infront of it. You should turn off the car, unplug these wires, then start the car back up. After you reach a certain MPH (I think its 19?) your ABS warning light should come on. See if the car still stalls...
s14_240sx
Car: 96 240sx Zenki
ABS in 240s hardley ever work correctly any ways, so just disconnect it.
