I'm sorry I didn't notice this earlier. First of all
to NICO!
The A/C system is controlled through the ECU. It's designed to cycle on and off under different conditions - one of them being that the evaporator coils get below a certain temperature. The goal being to keep them from freezing up... I believe thermal protection on the compressor is a one-time thing - as in it gets too hot and melts... kind of like a fuse. For the compressor clutch to engage, the thermal protection, thermo control amp, and dual pressure switch all have to be "happy."
The closest FSM (factory service manual) we have is for the 1990 Hardbody - but I suspect they're very similar if not the same. You can download it at
http://www.nicoclub.com/FSM/Hardbody/ Be patient and give it a few minutes to open, it's a big file.
There's a schematic on HA-46 and a wiring diagram on HA-47 that give a lot of information on how everything works...
Is a/c not keeping the truck cool enough? Some cycling is normal... if the evaporator is freezing up I think that usually points to a low refrigerant charge - but I couldn't say that for sure...
Good luck!
Heath
