Strang turning off issue
Sil80sushi
Car: 90 240sx
So my friend has a S13 with a redtop SR when he trys to turn his car off by turning the key in the ignition to the off position the car does not turn off till he takes the battery cable off i dont have much more info on this but any help would be great and ill try to get more info if needed
Sil80sushi
Car: 90 240sx
well my friend started to disconnect and reconnect everything just to see if maybe he missed somthing but it still does the same thing does anyone have any idea? maybe somewhere to start looking cuz we have no clue where to start
goalguy02
Car: '92 240
I am in the same boat sort of. I turn mine off and it runs for like 3 seconds then dies. Tell me, does he get a buzzing sound from his ignition relay after turning the car off?
Im still hunting down my problem. Didn't do it before the swap, now it does. Redid all wiring and grounds, Im lost.
T-rev
its either one of two things:
"Dieseling" buildup of carbon and the engine just sort of keeps detonating for a little while until the residual fuel runs out. Never had this on the 240 but did on my old carbed camaro
or could be a burnt out diode in your ecu
Sil80sushi
Car: 90 240sx
he said no dinging when you turn the key off guess it just stays on and i dont think its the detonating cuz the car stay on not staying on and dieing later
goalguy02
Car: '92 240
T-rev wrote:its either one of two things:
Is there a certain diode that would be culprit or does the ECU need replacing?
T-rev
there is a diode but I dont know which one. I tried to figure out which part it was, a while ago testing one of my burnt ecu and my good spare but I couldn't nail it down. There was a thread ago by a guy named Ross (I forget his screen name) where he was trying to solve it too, I could give you his email address if you wanted. The last time I talked to him it was still a bit of a mystery
The closest I got was this guy, [email protected], said he could fix it for $60. At the time I had 2 spare ecus so I didnt need it repaired, I just have another paperweight.
goalguy02
Car: '92 240
Well thats some good info. Ive been dying over this issue. I was going to get another ECU for ROM tuning anyhow so I will see if it helps.
Thanks again!
