cleets-s13 wrote:the way the fan clutch works is when the clutch is cold the fanwill not turn as much. when the engine worms up the coolent in the radator the air blowing over it will heat the fan clutch. when this happens the clutch will engage and pull more air through the radator and cool the engine. a fan type clutch will turn all the time this is its desine. as for tyhe waterpump it is made to turn all the time. if it didn't the coolent would not flow throughout the engine.
