Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Tue Mar 28, 2006 6:12 pm
"I HATE it when someone says this... the loss of power with large diameter piping on N/A cars is because you are loosing velocity not back pressure"
...actually, this is also off-base. Getting positive cylinder fill requires some back pressure. Sure, too large a diameter wcan impede velocity, but typically not to the point of reducing the valume of exhaust that can be sent through the system. This works for intakes as well (larger throttle bodies, mani's, runners)....up to a point, you generally gain more valume of airflow because of the increased area than you lose from velocity.
N/A cars (unless their running high exhaust valume and very high revvs, typically) require some back pressure to ensure the combustion chamber fills with air correctly (positive fill).
So yeah, although some of the loss from mega-sized exhaust could be from velocity loss, that isn't the whole story either.
-Chet
