JdsCoupe wrote:You're saying the car feels quicker with the rl ypipe than when u ran the 13.9 with your exhaust unbolted?
If I were to just straight pipe it after the first two cats wouldn't it have the same effect as the RL ypipe? I'm currently running a 3 inch cat back leading to a 2.5 inlet muffler. Do you think running a 3 inch straight pipe would be too large and hurt performance? I'm tryin to decide between 2.5 and 3 inches.
we only have 1 cat on our cars, the other 2 are pre-cats. when I unbolted my exhaust and ran that 13.9 it was AFTER the cat. So if someone had a racingline y-pipe (which deletes the cat) and unbolted their exhaust, they would probably run faster than a 13.9 (assuming they had the same weather conditions and altitude as when I ran my 13.9).
you could straight pipe it after the pre-cats but their isn't a lot of room there and I'm told you would also have to buy flex pipes (unless you used the stock ones) which would make the price similar to the RL y-pipe. I used to think the RL y-pipe was over priced and over rated so a while back I had a shop replace the flat part of the Y-pipe with 3" piping and delete the cat. I lost low end power. I later added the cat onto the y-pipe and gained SOME low end power back. I finally just bought a RL Y-pipe and I had huge gains down low and huge gains up high.... long story short, the RL Y-pipe works really well, I've had my cat taken off, I've had 3" piping, but nothing worked as well as the RL Y-pipe in that area.... for the rest of my car I've always ran 2.5" piping. so I think to make the car fastest, you'd buy a RL Y-pipe and then do 2.5" or 3" back. Going 3" will probably make you lose some low end power. but the gains may be worth it since I was able to get a really good time with no exhaust at all. only worth it for the track IMO.
sorry to make this so long, I've had a bunch of exhaust set-ups on my car and I'm still not even done lol
