fyarf »
https://forums.nicoclub.com/fyarf-u259099.html
Wed Feb 10, 2016 11:39 am
We have 3 cats in the 3.5: one in each manifold (regulated) and a third in the exhaust line (unregulated). The racingline y-pipe deletes the third unregulated cat. This will not throw any errors, as the ECU doesn't "see" it. If you don't touch the headers, nothing else should throw an error unless you have a fuel/air ratio problem. Removing mufflers or a resonator shouldn't throw an error unless there is not enough backpressure or too much air for the fuel being supplied by the injectors.
Loosening the bolts on a flange in any exhaust line sounds like a bad idea. air leaks=lost back pressure and power, and probably crappy sound. Since our motors are mounted transversally (one manifold toward the grill and one toward the cabin) changing the headers is a pain and is very difficult. It is possible though, and you will have to tune the missing cats out, or put in faux cats or something. If you want to bypass the muffler, take it to an exhaust shop and get them to remove the muffler, and weld in piping to the tips.
I wouldn't endorse this, as sound will probably be obnoxious. But it's your car, do what makes you happy.
