mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Tue Mar 11, 2008 12:55 am
I am swapping out an engine with transmission from another 90' that was rearended. I drove it home and the transmission felt nice and firm when it shifted so I decided to swap out the transmissions also but I want to keep the one that was in my car for backup incase the other goes bad. I don't know how long it will sit depending on how long the other transmission lasts. So you say that I should fill the transmission up and hook a pump to it to circulate fluid? For how long would I run the pump for and how often. Also do I have to rotate the torque converter and run the shift selector thru the gears when the pump it on?ThanksMatt
