stop the wheel hop on my 06 se-r spec v ?
bcbthomas
Car: 06 nissan sentra se-r spec v
I see on all the different websites , people say different things about the wheel hop on the sentra se-r 's . Can you recommend anything for my car on the wheel hop problem?
nametakennow
Car: '06 MINI Cooper S
Energy Suspension motor mount inserts and a good suspension are the best two mods for the wheel hop issue.
spec-bre
Car: 2002 Nissan Sentra SE-R Spec-v
ES MMI's and a Weapon R TQ Damper. I also hear that the Nismo lower tie bar helps.
bcbthomas
Alright . I will google it and see what I can find . Not really knowing what I am doing so I will try to find it . Thanks...
the technican
Car: 04 spec-v, 91 sentra hoping to be an srdet swap, 89 maxima
You might be able to get some inserts from nissan through the nissan motorsports catalog i got mine from there but i have an 04 spec-v dont know if they have anything for an 06 yet....but good luck that will help alot
nametakennow
04 and 06 were the same.
Yes, Nissan offers some high-durometer rubber mounts, they're a compromise between the increase in vibration from polyurethane ones and the wheel hop issue with the stock rubber ones. The urethane ones are better if the goal is purely to kill wheel hop, but if you find it only a minor problem, then the high-density rubber may suit you better.
D3stro
Vibration are only worst when all possible accessories are on such as: AC/defrost. You can get a lot of vibrations on cold time too, mostly at winter.You get used to it pretty fast. It's only your passengers who will always complain. Otherwise than that, MMI + torque damper is a good add on to have no wheel hop at all. Plus, with the torque damper, shifting gear is easier too.
Do it!
94 Sentra-XE
Car: 94 sentra XE
i saw on a nother site someone got the poly eurothane motor mounts and filled them with high temp silicone to give it extra support but vibration dampening
