Post by JZX91-2JZ » https://forums.nicoclub.com/jzx91-2jz-u119837.html Tue Nov 11, 2008 4:33 am
Post by the converted » https://forums.nicoclub.com/the-converted-u57671.html Tue Nov 11, 2008 1:18 pm
Post by maxnix » https://forums.nicoclub.com/maxnix-u127.html Tue Nov 11, 2008 1:55 pm
Post by goody90q45 » https://forums.nicoclub.com/goody90q45-u31761.html Tue Nov 11, 2008 3:20 pm
On the 90-93 the bottom 2 sockets on the module are the ones subject to melting. They have dual filaments vs. a single filament in the upper bulb. Inspect the socket for signs of melting or charring or brittle wires/melted insulation. Ditto for the bulbs. If the two contacts are melted or flattened replace with Sylvannia LL. (Hopefully they're available down under.)maxnix wrote:.....Inspect all bulb sockets and wiring for corrosion and melting.
Post by AlabamaDan » https://forums.nicoclub.com/alabamadan-u438.html Tue Nov 11, 2008 7:56 pm
Post by JZX91-2JZ » https://forums.nicoclub.com/jzx91-2jz-u119837.html Mon Nov 17, 2008 12:04 am
Post by maxnix » https://forums.nicoclub.com/maxnix-u127.html Mon Nov 17, 2008 5:11 am
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
