Stop Lamps Switch Spec.
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Rastaman79
Car: Nissan Tiida 2007 (AKA Versa)
Hello everybody,
I have a 2007 A/T sedan Versa, imported directly from Japan factory as Tiida. My stop lamps (brake lights) switch (the one located next to the brake pedal) has stopped working and I am looking online for a replacement (local dealer sells the switch 5 times the online price and there is not availability on stock).
According to online suppliers list, the proper part number for my car is 25320-AX00C. I checked a picture of this part, and It seems to be only two pins in the male plug, while the switch installed in my car has a four-pin connector.
Anybody knows whether this is just an issue with the angle in which the picture was taken, or is it that the switch 25320-AX00C has actually only two pins? If so, what would be the part number for the 4-pin switch?
Many thanks in advance for your help.
Athikerguy4life
Car: 2008 Nissan Versa
im not sure what this part is.. Stop lamp?
Rastaman79
Athikerguy4life wrote:im not sure what this part is.. Stop lamp?
I mean the brake lights, the tail lights that turn on everytime you press the brake pedal.
Return to “Versa Technical Discussions”
