I agree.AZQ45 wrote:I went through the EXACT same thing you are and everything failed until I did what I described above. Others have posted similar stories as well.
They are the only acceptable substitute.squeefoo wrote:Wow ! Good job finding this old thread! I found if you ohm the "good/stock" old bulbs in the back and check them against Sylvania LL's they're the same ohm's.
