Stop lamp inoperative
tmak26b
Car: 95 Q Boat
I replaced two light bulbs at the third brake light, but the stop lamp inoperative won't go away. Any ideas?
Thanks
This is on a 95
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
If you use non-OEM spec lamps it can appear to the car as though the lamp is still bad. Make sure you get a Sylvania (regular or long-life) lamp as a replacement.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Did you replace with sylvania long life?
How were the sockets for the tail lights, were they burnt?
Check the stop lamp sensor.
Clean socket with electrical parts cleaner then add dielectric grease.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Did you use cheap Chinese bulbs sold by NAPA? If so, better inspect for burned wires and sockets. The lamp is telling you you are drawing too much current because the resistance is too high.
OEM or Sylvania LL only! All else is a gamble. There are probably already a half dozen different threads with similar titles.
tmak26b
Car: 95 Q Boat
thanks all
Infinitiguy19
So what fixed the problem?
TBrack
Car: none
It kind of makes me mad nissan did this. As nice as the lan system is I think it should give you a warning and keep the power going to the bulb. I only say this because it makes it really tough to make led stop lamps
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
All you have to do is match the expected current draw.
tmak26b
Car: 95 Q Boat
ppastos wrote:So what fixed the problem?
I havent fixed it yet, but I just replaced the light bulb with something I had in my drawer. I will buy a new pair
TBrack
Car: none
maxnix wrote:All you have to do is match the expected current draw.
Yea I tried everything my limited electrical knowledge will let me do. Load resistors don't seem to work
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Don't feel bad, you are not the only one. A few LED rear tailight projects have gone by the wayside. Time to get an BSEE on it. I think it is pretty low on Dennis' list.
TBrack
Car: none
maxnix wrote:Don't feel bad, you are not the only one. A few LED rear tailight projects have gone by the wayside. Time to get an BSEE on it. I think it is pretty low on Dennis' list.
Yea, I actually had the one Wes had. The thing wasn't even set up for 12v! The guy (whoever made it) had it built with a 10v battery powering it... I'm working on my BSIE and we don't really work with electronics so what do I know
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You're lucky he didn't bestow the supercharger project to you!
tmak26b
Car: 95 Q Boat
Replaced the two bulbs with a package of the new packaged Sylvania 921LL bulbs, didnt fix the problem. I then bought the old package, fixed the problem. Weird.....
goody90q45
Car: 1992 Infiniti Q45 (sold)
All the brake lights are on one circuit and run through the brake lamp sensor mounted below the trunk lock. I think what the warning message is tellling you is that there's high resistance in another part of the circuit. Take a look at both brake lamp modules, they come out with the squeeze of the fingers. It could be as simple as melted (flattened) leads on one of the bulbs.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
tmak26b wrote:I then bought the old package, fixed the problem.
What does this mean?
Infinitiguy19
I think he meant, he bought the old bulbs that were the ones to cause the problem in the first place.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
ppastos wrote:I think he meant, he bought the old bulbs that were the ones to cause the problem in the first place.
Really? So something is still wrong then.
I didn't understand he had to buy something he already owned?
Oh well.
Infinitiguy19
Well like Denis said over time the little wire in the bulb that make the light bulb work gets thinner and thinner over time so by replacing with a new but incorrect bulb fixed the problem for him.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
ppastos wrote:....so by replacing with a new but incorrect bulb fixed the problem for him.
That's not possible. Either it works becasue it presents the correct current draw or it doesn't. I wonder if the original bulb was not seated correctly?
Something is screwy.
slybydesignq45t
Car: City Bus
I have a question. When my brake light came on so did the Stop Lamp Inoperative light. Don't the two correlate with each other? I thought I read some where that SLI will come on when your brakes are worn.
tmak26b
Car: 95 Q Boat
Sorry, was typing on my cell phone.
I meant to say I bought a pack of Sylvania LL bulb (ones with the new lettering and looks to it). It didn't work. I went back into the store and bought a pack of the Sylvania LL bulbs in the old packaging. They worked. It's weird...
The bulbs I used from my toolbox were 916, different than the 921 that is needed.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Thank you for the clarification.
I was thoroughly confused.
