Marconelly wrote:specialist23 wrote:it's normal
No, it most definitely is not normal.
You beat me to it.... lol,
That's got to be one of the best posts in the history of the internet.
Raw gas and partially burned hydrocarbons are two separate but very important things...Things that you should not have to worry about. However since it seems like this might be something worth looking into.
Given your car has a "normal" service history.
I would first look at the fuel pump, since there was a recall on the 08s and the majority have been serivced at one point. From there I would move forward in the fuel circuit. The single high pressure line is a near perfect system in that it is simple and has little oversight, although a fault will be quickly detected.
Hydrocarbons (HC) are one of the top 4 controlled tailpipe emissions if there is an issue it needs to be addressed.
Your EX has two very complex systems dedicated to nothing but controlling fuel vapor.
The Evaporitive Emissions system removes fumes from the fuel tank and stores them in charcoal and burns them under certain normal conditions.
The On Refueling Vapor Recovery (ORVR)system captures the HCs displaced during refueling and stores them for burnoff later.
The control of the "smell" of gas is very important and not something that an owner/operator should have to worry about. If this is something you can replicate, or if you are experiencing a leak or driveability stumble (fuel leak under load). Or if something "feels" off when you smell the smell get it looked at asap.
