brainguyus »
https://forums.nicoclub.com/brainguyus-u96042.html
Sun Jun 28, 2009 7:09 am
Ok, I just completed replacing the headlight extension panel. Not a hard job, but you need to be careful of the 6 pawls along the lower part of the grill.
To remove the grill, the service manual says to remove all the pins along the top, release the two clips on each end of the grill using pliers, then pull the grill straight out to pop loose from the lower six pawls.....easier said than done....I snapped one of the pawls following this method . Fortunately there was enough surface that I was able to firmly re-attach it with some gorilla glue.
It's best to wiggle your hand in there with a small screwdriver and manually release each lower pawl while applying forward pressure on the grill. Small hands help here....which I do not have.
Modified by brainguyus at 1:35 PM 6/28/2009
