austins240 »
https://forums.nicoclub.com/austins240-u9789.html
Mon Jun 25, 2007 4:36 pm
you got the car back intact after being stolen!!! wow, that's a pretty good ending to a bad situation.
i would personally drain, remove, clean the gas tank. who knows if they put anything in there. not that bad of a job either. and clean/replace the lines.
i'd drain the oil, then refil with the valve cover off to make sure all the cam lobes are lubricated. 6mos isn't long but you wanna look in there anyways and it's easy.
and yeah, crank it over with the CAS unplugged to build pressure. might be a good idea to pull the exhaust and blow it out, make sure no mice got in there for nesting hehehehe same for engine bay and under dash (wiring short fires ftl)
your PS and brake fluid should be good. might wanna change the MT fluid, don't know if the hozers that stole it could drive.... >_>
but at a minimum, fuel treatment and some HEAT (water remover), fuel filter, and oil/filter.
