stock wirage question
Post all your Nissan electronics, car audio and stereo questions here!
FiZ
hey. i was wondering if anyone knew how the stock wires are ran through the car in a S14 with the crappy amps in the back and compoentns in the front. I need to know if i will have to rewire them because im plannin on running a power cable from the battery to the amp and i dont want any noise..
thanks a lot,tom
Former_240_s14
Car: 07 BMW 335i Coupe
I ran my power wire for my amp on the passanger side, and I hear no noise whatsoever, plus I think you are mistaking the RCA wires with the speaker wires................ the RCA's you wanna run on the other side.......
FiZ
thanks.. no i meant the stock wires. they have to run to the amps int he back and then back to the fronts. meaning they either go on the left side or the right side of the car. So i dont want to run the powercable for the amp next to them..
i kinda want to stay away from rewiring the whole car ..
tom
Former_240_s14
well if you are using a new head unit, you may have to unless you buy a pre line out converter, and I still would suggest then to not do that...................... I don't know if the stock head units are pre line out only, or if they actually have power.......
FiZ
hmm i dont think we understand eachother. My plan is: Get aftermarket headunit and plug it using a harness to the stock wirage. By-pass the stock amps and take them out. Install new speakers in all corners. Then install an amp in the trunk with a subwoofer.
So i need to know, when i install the amp in the truck will it intefere with the speaker wires going from the headunit to the trunk to the speakers..
thanks for your help
Former_240_s14
OOOOOKay, now I understand what you are saying, I am very sorry for that, lol!
The wires should not interfere with you amp, at least not enough to let you hear a difference................................................
does this finally answer your question? sorry about that again, I can be an idiot sometimes, :)
