stock wheels bigger tires size help
Nissan 350z / Nissan 370z general community discussion forum
QM888
Car: 350z
my stock wheels size 18x8 f and 18x8.5 R. Can I put 245/40/18 F and 275/40/18 R. my car is 350z 06 enthusiast. please advise.
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
I believe if you search there's a tire calculator some where in the tech forums.
bmike818
Car: 2007 Z
NSRsheets wrote:I believe if you search there's a tire calculator some where in the tech forums.
thats not the question, I am actually waiting to see that combo on the tsock rims...I want to keep my stockies but have a much wider tire put on it.
So if anybody knows if the stock 18x8 and 18x8.5 will handle the wider tires please let us know
QM888
Car: 350z
+1 please help
IndyZed
Car: 2007 350 Z coupe / silver alloy
Go to Tire Rack's website and find the tire & size you want then go the specs page. They list everything about the tire and the widest wheel it will fit.
IndyZed
QM888 wrote:my stock wheels size 18x8 f and 18x8.5 R. Can I put 245/40/18 F and 275/40/18 R. my car is 350z 06 enthusiast. please advise.
Okay, According to Tire Rack the answer is yes to both questions if you use the same Bridgestone tires.
If you use a different brand it might not work. Tire Rack says a 245/40 will fit rim widths 7.5" - 9.0"
275/40 will fit 8.5" - 10.5" rim widths.
bmike818
Car: 2007 Z
thanks for taking the time to help out
QM888
Car: 350z
thanks alot. so if i go for kumho escta SPT 245/40/18F and 275/40/18Rwould this fit my stock wheel? do i need wheel spacer?
IndyZed
QM888 wrote:thanks alot. so if i go for kumho escta SPT 245/40/18F and 275/40/18Rwould this fit my stock wheel? do i need wheel spacer?
According to Tire Rack the Kumho 245/40 will fit the front wheel but the 275/40 will not fit the rear wheel. It needs a 9" minimum rear wheel width.
NSRsheets
I don't believe they will work. You will most likely need 8.5 in the front and 9 in the back.
Return to “350z / 370z Discussion”
