Stock Wheel Weight
DredM56
Car: 2011 Infiniti M56 2004 Subaru Wrx STi
Anyone ever weigh a stock rim before. Curious what they weigh thinking of getting some light rims if there is enough weight to be saved. Non S 18"
Ilya
According to this EBay listing, they are 27". So yes, you'd probably save a ton of weight if you got 18lb 18's, etc.
http://www.ebay.com/itm/2011-2012-2013- ... Bu&vxp=mtr
DredM56
Yeah I emailed someone on eBay selling them they said 25-30 was just hoping someone had a definite answer. I'm looking at a set that weigh 18.2
k67p67
Car: 2015 Infiniti Q70 Premium
2017 Nissan 370Z Nismo Tech
Sport 20" are about 32 lbs.
nebojsa_o
Car: 2012 Infiniti M37x
2002 Nissan Maxima SE
1996 Oldsmobile Cutlass Supreme SL
2007 Suzuki GSX-R600
When I took my 18's with Michelin Primacy MXV4 tires off the car, they weighed 58 or 59 lbs if I remember correctly. My new aftermarket 20" rims with 245/40 tires were 61 lbs.
DredM56
Thanks that helps tire rack says the tires are 28lbs. That again falls into the 25-30 I've heard so far.I like your number I hope they're 30lbs. I'm thinking the light wheels will be a good investment.
I saw a test done on a gti with multiple different wheel set ups. A 6lb drop per wheel same size though equalled a .1 in the 1/4 plus 1 or 2 mph don't remember which. 14lbs heavier and larger wheel was .2 and 2mph.0-60 was .3
It's looking like. I'll save 9lbs to 12lbs.
