stock wheel offset
BoneDizzle
I just wanted to know what the stock 240sx wheel offset was. I am sure this is somewhere on here but the search feature isnt working for me so i figured this would be faster. thanks
black s13
40, you could have searched the wheel, it says it right on the front.
BoneDizzle
so if i got the 5zigen FN01R-C which have a 35mm offet i would have to get 5 mm spacers to make them fit right?
black s13
no no no... go to google and type wheel offset and read... ill explain quickly...
the lower the offset, the further the wheel will stick out (generally.) stock offset is crap, and looks bad, you want a lower offset. spacers lower the offset, not raise it. if you have a +35 wheel, and put a 5mm spacer on, it would be like having a +30 wheel. in order to look decent, on a x7 wheel you need an offset aroud +20. if youre spending the money, get the right offsets, dont use spacers.
