streeteg »
https://forums.nicoclub.com/streeteg-u61203.html
Thu Jul 23, 2009 6:44 pm
Thanks for the responses guys--- The car is a completely custom Datsun with a dash that only has autometers in it-- so there is no need for the OG sensor that goes to the stock cluster. That being said--- the autometer sender is smaller then the stock sender-- making it impossible to tap and fit in. Not to mention the actual sensor below the threading is thicker then the stock-- so you would have to drill out the manifold, and find some sort of 1/4" adapter to make the sensor fit, then run the wire. Way too much of a hassle.
I beleive the FC will show the temp off the stock sender, and I will have the autometer sensor in the heater hose just after it gets back from the radiator (after the oil cooler and turbo water lines etc.) So it will be cool to see the temp differences after the rad. Anyway Ill probably have some pictures up after its a wrap tomorrow. Thanks for the help again
-Eric
