Stock wastegate issue??
NiceLyphe
Car: 1992 Nissan 240sx
Alright well recently my SR all of a sudden wants to start hitting 9lbs at full boost rather than 7. Currently using the stock T25 with stock wastegate, FMIC. Started doing it this week. Ideas?
Thank you!
S13 Blacktop SR
FMIC
Exhaust
Stock ECU
HKS SSQV
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
May be some boost creep?
NiceLyphe
Possible wastegate going bad?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Wastegates can go bad one of 2 ways. 1 the spring gets week and you loose boost, 2 the diaphragm leaks making it not possible for boost pressure to open it accurately resulting in over boost. Any leak in the line from charge pipe to wastegate will do this.
NiceLyphe
Changed the line, still hitting 9. Dont get it..
compactfean
daily
Do a boost leak test...I bet the wastegate actuator leaks air.
codyace
Car: S14 w/redtop
Internal wastegates suck, at best. More than likely wear and tear.
The only true boost control is a new aftermarket one kept below 1 bar, or having a wastegate welded to the OEM manifold. I can help you with both.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Helper springs work really well too...
