WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Mon May 05, 2008 9:23 am
Well, sounds like you went from NA to boost with forged pistons. If this is correct, then you'll have slightly less power off boost with the turbo because of the mani design and back pressure from the turbo.
Other then that, no, pistons with the same compression ratio and design shouldn't effect the driving.
WD
