Stock vs Aftermarket Replacement pads and rotors
542keith
Car: 98 Nissan Maxima GXE
I'm looking to replace my pads and rotors on my 98 max gxe. I've experienced pure hell with after market pads (squeals and pads shifting in the caliper) I've heard a lot of horror stories about aftermarket pads as well.
I'd like to go with slotted rotors and stock pads. The slotted rotors for improved performance, and stock pads for the best compatibility with the stock calipers.
Any thoughts out there?
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Slotted is a good option, do not waste your $$$ on cross drilling. As far as pads, get Hawk HPS pads. They were a direct replacement fit of the stock, have low dust, do not squeal, and stop you a little quicker.
Proper burnishing of the pads will eliminate a lit of the problems you may encounter also. Just as well, don't forget the anti-squeal between the pads and calipers.
542keith
I'll give the Hawks a try if it will fit like the stocks and stop that sliding.
Any particular brand of slotted rotors you recommend? Also, what do you think about painting the calipers?
Beancooker
Powerslot. I have heard a lot of good about them.
Don't be like me. I was lazy. Painting your calipers is something that should be mandatory when doing your brakes. You will regret it if you don't. Get a high temp paint also. Pick up a caliper tool also. It connects to the end of a sockit wrench to make twisting the pistons in, a whole lot easier.
542keith
I appreciate the advice. I'm starting slow with the mods but I figured I'd start with the brakes.
danielekfuj
Car: miata, rocket ship
anti-squeak is a must, I also used some grease for the edges of the pads so they slide easily and don't bind and on the bolts that the caliper moves on, helped a bit i think. Im not sure what that stuff is called but they should have it at your local auto parts store. You can also usually loan a caliper tool for free at your local store.
danielekfuj
also used dupli-color black caliper paint, did 2 coats and lasted for 3 cars :D i thought it came out pretty good too, and it's still there i am thankful i didnt buy the spray can of paint, it wouldve been hard to paint what you waned w/o painting what you didnt want, IMHO
542keith
Good advice as well!! I'll try the grease, the anti-squeak, and the duplicolor.
rmd0311
Car: 2001 Nissan Maxima
Why is painting the calipers a must? What is the performance factor for doing that?
BTW., love your sig, who's that girl???
