swimshark »
https://forums.nicoclub.com/swimshark-u57894.html
Wed Nov 17, 2010 12:27 am
first off like Jdurrty said, the compression is totally different and the oil pump on the NA is different from the TT
the oil pan is different
you will need to get TT ac lines or get some custom made (these will get in way of turbo piping on drivers side)
relocate battery (so you can route turbo piping down to bumper. if running dual smic it will be easier, and will need bracket made to hold the intercoolers)
relocate fuel filter and maybe PS reservoir (i personally would not trust fuel filter being that close to the hotside of the turbo and PS reservoir may get in way of turbo piping))
motor mounts modded (Zs have a 2 bolt setup)
will need a custom ecu, boost controller, run tubing and wires for gauges also
id go with the 5speed cause the RE401A J30 trans are only good for 260hp so it will die quick.
ive bene considering the project and have done my research. have a 600+ whp all day build in mind
