Stock type suspension spring with 4 kg/mm or more rate?
xagna
I have two rear KYB AGX struts.I am looking for springs. Because I have two megan front struts with 6kg/mm spring I would like to put 4 kg/mm or more rated spring on the SGX struts.
Do you know any springs with 4 kg/mm or more for stock type suspension struts? Where can I get them?
naed240sx
Car: .....
RSR race or down springs.
Your KYB's won't put up with them though.
xagna
You mean AGX will blow up soon after the spring install?
naed240sx
Car: .....
correct.
AGX are a stock replacement strut. They are not designed for higher spring rates.
