Yea you need a gauge to make sure you set the Fuel pressure properly. I believe it needs to be ~43 PSI w/o the vacuum line hooked up, then under vacuum it drops to ~35ish. Nismo FPR is your easiest route and then whatever fuel pressure gauge you want. I went with a B&M FP gauge for like $30 off of jegs or something like that.jb96s14 wrote:with a nismo fpr you have to install some kind of a gauge so you can set the fuel pressure correctly right ? isnt the correct pressure for that like 45psi at the gauge or something i think that i read that somewhere. ive got the mbc at 10 psi but thats not so bad. i have a replacement turbo already i bought it for my ka-t that never was but its an rb25 turbo. and the manifold was glowing red also. i should own that god damned m3 rich or lean or in reverse
Modified by jb96s14 at 4:35 PM 8/9/2006
13psi stock turbo/ ecu is wayyy to low to worry about popping the engine. If anything it's way too rich due to the stock ecu going into R&R...rbsileighty wrote:Turbo should be ok at 13psi... but if this is a RB25... be careful pulling out fuel (esp on a hot day)... I wouldn't worry about the turbo at that psi as much as I'd start to worry about popping the motor... or start filling up with 100 or 110...
decent readhttp://www.faqs.org/faqs/autos....html
Don't forget 25's are 9:1... and that octane at a shared pump (87-9x) isn't always that consistant...
