Flybert wrote:My friend has his CA up and running pretty well right now and he's looking for some more power. We're considering three options and money is an issue. He already has a FMIC and I'm going to give him a spare walboro I have. This car is used as a daily driver and at the track and usually gets 100 octane when we are there.
Option 1 - get a boost controller and kick up the boost until he gets somewhere around 220whp.
Is it true that a stock CA MAFS maxes out at 220whp? What boost can you run on a stock turbo to get around that amount?
Option 2 - get a boost controller and SAFC2 and use an S13 SR MAFS and run as much boost as safely possible on stock turbo and stock injectors while being able to monitor knock with the SAFC2.
Is 15psi max boost before losing efficiency like on s13 SR t25?
Option 3 - get an s14 ball bearing turbo and run stock boost at 7 psi. Will an s14 turbo at stock boost make too much power for a stock CA MAFS? When do GT28R's make full boost on CA's?
I've done a lot of searching on this forum and the answers to my questions are pretty hard to come by so take it easy on me.
Option 1-Won't happen SAFELY on the stock setup. You'll hit boost cut on the ECU, possibly max out the AFM, injectors, and will be seriously over spinning the turbo. I've got a very well built CA and at 15psi I'm just under 200rwhp. That's about 220 HP at the flywheel, but you won't get that on a stock CA at 15psi. Also the turbo is MAXED OUT at that point.
Option 2-WAY BETTER than option 1. You'll still be close to the limit of the injectors, but with the walbro slightly over fueling the engine anyway, you'll probably be ok.
Option 3-This is the best option as you're keeping the intake temps to a minimum and the turbo isn't working very hard. If he's on the stock exhaust mani he should hit 7psi around 3K rpm (proabaly lower). I don't think you'll be maxing the MAFS out a that level yet, but once again, my main priority would be the stock injectors as they will be close to the limit.
