Stock T25 - Using gasket maker/RTV in place of 5-bolt outlet gasket?
Project240
I'm trying *really* hard to find an OEM 5-hole outlet gasket for my SR's T25 before Wednesday, when I'm installing a high flow O2 housing, and simply can't. Not without paying $40 for overnight shipping
Is there a silicone (or other) gasket maker that would do the job? I'm not too optimistic since it would have to deal with some serious heat, but >$50 is a lot to pay for one little gasket
SpeedRacer1
Car: 1990 240SX, G35
You can only use a copper or other organic gasket. RTV will eventually degrade and blow out.
jr_ss
Car: 95' S14
^ What he said.
That outlet see's temperatures 700-1400 degrees depending on your car's health, it'll basically melt. Even a used one, is better than none.
Project240
Yep, that's what I thought. Guess it's anal violation via shipping charges for me Thanks guys.
garagelu
Car: 1995 240sx w/ sr
Permatex actually makes a copper liquid gasket that is for turbo applications. I dont recommend using it as a permanant solution though but it will work fine. When I had my engine out I lost my 3 bolt exhaust gasket in the process so I used liquid gasket for now. It sealed fine.
Project240
...So how bad would it be to re-use the old gasket? OK as long as it's in one piece? If not I'll just put off installing the elbow until later
Hijacker
Car: '92 240sx Convertible
'94 F-150
If it's in one piece, it's fine. It's a metal gasket, not crappy paper.
onecrazyfoo4u
Car: 03 Type S
Yeah, as long as it's in 1-piece, it's fine. They're not crush gaskets like the cheapo exhaust ones are, they're solid metal, that form to the right shape when put under pressure. It should seal just fine!
Project240
tenkawa_akito wrote:It's a metal gasket, not crappy paper.
I don't know why I didn't realize this. I was picturing taking the elbow off and scraping the remains of the gasket off with a file.
So that's good news Much thanks guys.
