rjdmmfl1 »
https://forums.nicoclub.com/rjdmmfl1-u77059.html
Sun Dec 21, 2008 7:09 am
Ok, you've got alot going on here... I understand what you are tryiong to do, but I would go about it slightly different!
1st, running your front speakers off of deck power is a REALLY BAD IDEA. Do you drive from your rear seat? No? Then why sacrifice/forfeit front stage audio sound and clarity by running the front speakers off of deck power?
If anything (and again, I wouldn';t suggest this) you would run the front speakers off of two of the channels of the amp, run the rear door speakers off of the other two channels, and run the 6x9's off the deck. The rear should only be for rear fill anyways, and you don't need a whole lot of power to go there! So that's how I would do it if you only want to use the 5 channel amp...
Run 6.5" components with passive crossovers off of two channels of the amp. Mount the tweeters in the factory 3.5" location, and the 6.5" in the door. Running passive corssovers, you only need two channels for this! Now, if you're gonna add speakers to the rear doors, you want to decide whether you want those speakers to only handle mid bass, of full range of sound. If you want them to handle the full range of sound, you need "coaxials" not components. Unless
A. you are gonna cut a hole in the rear door to mount the tweeters, then you can use component or
B. You purchase a set of components that allow you to mount the tweeters on the midbass driver, giving it the appearance of a coaxial setup for installation purposes.
But if you just want there to just be midbass, then you want a set of midbass/midrange drivers for the rear doors... either way, you could run these off of the rear channels of the amplifier. And again, you could just run the rear 6x9's off of the factory deck, and run the woofer off of the 5th channel on the 5 channel amp.
Alternatively, you could also run an additional 2 channel amp for the rear 6x9's! In either case, if I were setting up your system, I would run three seperate amps, and an active crossover setup, but that's just me!
OK, you could get some 8" woofers to work in the door, but it depends on what kind. Ideally, you want your doors to carry midbass, not sub-bass. So you don't want subwoofers in the doors, you want something like some good 7" or 8" dynaudio woofers to go there. These woofers mount very shallow, and you could easily get them in the rear doors with a little modification!
MOst subwoofers don't work well in free air conditions.. so putting a real subwoofer in the dorrs is a bad idea!
