Let me be straight with you here...I redid mine, wire and and all. If you are down to the amps for the speakers....that means you can SEE the speakers....and it would be much better to replace them then as the Bose speakers are complete crap anyways and you probably wont like what your getting out of 15+ year old speakers. Simply, just remove some panels, run new wire (easier than it sounds), splice in the new speakers, hook these wires to the new radio pigtail. Get an antenna adapter, and a wiring harness adapter ( ziptie the Bose connector back and electrical tape off). Use the power and ground wires off this adapter to hook onto the new radio pigtail. Hook up the antenna. This will basically allow you to convert the old Bose system to a single DIN setup with modern connectors using the old harness. The next time you replace it, it will be plug and play. If you have any questions ask me.....its the one thing i know like the back of my hand on these cars.carrottop596 wrote:Where can I purchase replacement amps for the original bose speakers?
Well from the number of Zs i have been in, they just dont have the quality they did in the 90s. The problem is, most of the arent in good shape like you noted. Upgrading the system will bring it up to current specs and clarity, which most people are used to. And maybe i overstepped calling it crap, but they sounded bad enough it wasnt an option to leave them in my car.TellarHK wrote:I would disagree that the stock speakers sound bad due to age. I have a '94 Infiniti Q45 with the original Bose system that still sounds great without a crackle or pop, and my roommate just bought a '93 Z with the Bose system which also seems to be in good shape so far. The Bose systems actually work very well when they're in good shape and properly tuned, and it's one thing I have never planned on replacing in my cars unless or until something does fail and I can't find replacement parts.
The only problem comes from the fact that you are buying something new to salvage a really old audio system. I mean, i got mine on sale, but i got kenwood shallow mount speakers for 100 bucks from bestbuy.carrottop596 wrote:Lets say that replacing the speakers is not an option for me right now. What else can I do? Would it make sense to put in a standalone amplifier that could run at 2 ohm to connect a new deck to the speakers?
I'm a complete audio nut. The Bose system is absolute crap. It sounds "good enough" for a stock system. That's about as far as I will bend on that. Whomever thought it was a good idea to change 6.5" speakers all around to 4.24" speakers all around and call it an "upgrade" needs to be dragged out behind the shed and shot. It's terrible.TellarHK wrote:I would disagree that the stock speakers sound bad due to age. I have a '94 Infiniti Q45 with the original Bose system that still sounds great without a crackle or pop, and my roommate just bought a '93 Z with the Bose system which also seems to be in good shape so far. The Bose systems actually work very well when they're in good shape and properly tuned, and it's one thing I have never planned on replacing in my cars unless or until something does fail and I can't find replacement parts.
Thats what i was trying to get across to him. If you are going to be messing with it and spending money...best to trash the amp idea and just buy speakers.Ace2cool wrote:I'm a complete audio nut. The Bose system is absolute crap. It sounds "good enough" for a stock system. That's about as far as I will bend on that. Whomever thought it was a good idea to change 6.5" speakers all around to 4.24" speakers all around and call it an "upgrade" needs to be dragged out behind the shed and shot. It's terrible.TellarHK wrote:I would disagree that the stock speakers sound bad due to age. I have a '94 Infiniti Q45 with the original Bose system that still sounds great without a crackle or pop, and my roommate just bought a '93 Z with the Bose system which also seems to be in good shape so far. The Bose systems actually work very well when they're in good shape and properly tuned, and it's one thing I have never planned on replacing in my cars unless or until something does fail and I can't find replacement parts.
I replaced all my speakers with $45 a pair 5.5" speakers from WalMart (so $90 total) and bypassed the Blowse amps at the connectors, installed an aftermarket head unit, and it sounds 93487592745961750891473 times better.
