Stock SR20 crankshaft nitrided?
ILikeMy240sx
Car: SR Power
I know that the stock crankshaft is forged and not cast so its fairly strong but does anyone know if it comes out of the factory nitrided? The reason why I ask is I am in the process of rebuilding my engine and getting the crankshaft machined... I wanted to know if I have to nitride the crankshaft after machining (a necessary process if it comes nitrided stock)
ILikeMy240sx
Car: SR Power
anyone?
namwons_240
Car: 97' 200sx ser
Not sure if it did from the factory or not but would if hurt to do it anyways if it wasnt?
ILikeMy240sx
Car: SR Power
no it wouldnt.. it would actually help. But the problem i.. I cant find a shop near by that can do that so if it didnt come nitrided from stock... Id rather not try to nitride the crank although it helps.
Hijacker
Car: '92 240sx Convertible
'94 F-150
it's not nitrided. I've had quite a few cranks machined over the past few years (obviously not for my motor) and have never had to have them renitrided
ILikeMy240sx
Car: SR Power
Hey thanks for that response. That's exactly what I was looking for.
BTW, did you have to get your crank balanced after machining? The machine shop is not taking alot of materials off the journal. Just a little bit to get rid of the tiny grooves that the bad bearings left.
Hijacker
'94 F-150
rebalancing wouldn't hurt, but it's not necessary if they're not taking off a lot of material.
