CRyan »
https://forums.nicoclub.com/cryan-u23575.html
Sun May 31, 2009 6:45 pm
Well - for a few months now I have been talking about WHEN my SR20DET gets in. Well.
ITS IN!!! S14 SR20DET "notchtop" complete swap WITH side mount intercooler AND working A/C and power steering. That is to basically sum you up. The engine was ordered through Japan Motor Import. So, as I do this swap, I will also give an overall review on just how good there engines can be.
Also - As of now the only parts I have ordered for this engine are a new aluminum radiator w/hoses, shroud, and 2 12" slim fans, AND an OEM oil pan.
I have only really done a walk around of the engine, taken some snap shots, etc., and this is what I have found. When you see a number with a asterisk beside it, That means there is a question awaiting on the bottom of the post.
1. For the most part, engine doesn't LOOK like it has any oil leaks. We will find out for sure soon, though.
2. Wastegate is aftermarket - HKS, but it is sealed so I don't want to take the chance of hurting anything trying to find out what color the spring is inside. We will find out what its spring is when I have it in with gauge.
3. There are a few male clips that aren't necessarily broken, but can be salvageable.
4. Throttle cable is cut. (1*)
5. Oil stick broke. Luckily, I was able to fish it out. (2*)
6. Has some iridium plugs in it, NGK Iridium T7340-7 (3*)
7. Intake manifold seems to have a little oil; has me a bit worried there might be a blown seal on the turbo in this case. Maybe it just happened to have just built up. . . .(4*)
8. Many vacuum hoses have been cut, apparently the last owner did have a boost controller with the engine, though.
9. Nismo flywheel and clutch. Guess thats one good thing about it.
10. SMIC seems a bit beat up, but looks like it will still be able to handle 10 psi.
1* - Will KA throttle cable work with SR?2* - Can I use oil stick from SR20DE?3* - Any other recommendations on the spark plugs?4* - Any other reason there might be this slight oil build up in intake mani?
OK, OK. . .On to the pictures. Also, PCM valve? You will see the picture. . . Why do I have it and why is the wires cut for it?
What is this?
Thanks for the help guys!
