stock sr power problem
LordOfTheMiasma
Car: s-13 hicas sr20det 240sx
I am sure it has been gone over before... and i searched around a bit but o well... i have my sr in and nothing more than a boost gauge hooked up. shows it boosting between 7 and 8 psi all the time.. but i got walked by a stockish ka.... timing is right, compression is almost perfect. I just dont know where to start looking. any suggestions? could it be a boost leak? the thing is on friends cars boost leaks mean it runs like ***. it runs perfect and sounds fine just doesn't have the power it should. any suggestions would be appreciated.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
I would recheck the igniton timing and make sure its at 15o Second mark from the left on the crank pulley..Maybe a clogged cat or muffler??
LordOfTheMiasma
rsr dp, 3 inch cat delete ( im in fl) and 3 inch apexi n1. and the timing is right unfortunately i wish it were that easy. we have double and triple checked it..
9240sx
Is your clutch slipping ?? Or maybe a Vacuum leak??
silverarrow27
You sure you're not too busy smoking those tires?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Is your ECU in limp mode?
C - ROD
Car: SR20DET pignose hatch
are u tripping ur computer into timing mode before u check the timing?
LordOfTheMiasma
Tripping the computer into timing mode??? im an sr newb sry if that was a dumb question. Why would it be in limp mode? thats what it is acting like but i duno why it would be. i Hve replaced the turbo, manifold, waste gate, checked timing with several timing guns ( duno baout the timing mode thing..) check compression and it was 156 across all 4... please help.. this is annoying.
whiplash willy
Car: 93 Coupe 90 SR Hatch
How do you check if your ecu is in limp mode? How to you get it out of limp mode, or is it automatic?
LordOfTheMiasma
cmon... this thing needs to run right...
9sec240
Car: S14.5 Turbo KA
9240sx wrote:I would recheck the igniton timing and make sure its at 15o Second mark from the left on the crank pulley..Maybe a clogged cat or muffler??
Second from the right.
-5° 0° 5° 10° 15° 20°
