blueballa »
https://forums.nicoclub.com/blueballa-u83809.html
Sun Oct 18, 2009 6:55 pm
hey. my sr is acting a little wierd. i had a vacuum leak a while back and my car would ide really high, as well as my timming was off. i found the vacuum leak and when i was adjusting timming i put the cas in wrong. When i attempted to start the car it pushed out smoke throught the intake. i readjusted my timming and it started up with no problems. it idles great, but it doesnt boost hard at all. the turbo builds up boost the same and the bov screams as normal but its not getting the same power as it was getting in the past. I just did a boost leak test and there were no leaks. i took off the intake pipes for the turbo and inspected the turbo, theres no absolutly no shaft play and the propellor spins freely. there was some oil in the intake pipes and around the turbo. but when i start up the car while its cold it seems like the propeller grinds with turbo housing. it makes theses scraping noises. when im in 4th gear pushing the car, it picks up speed but nothing like it use to, but the turbo is boosting. the power isnt getting to where it needs to get. any suggestions would be very appricated.
thanks
