stock speedo with sr
boost_creep
Car: 92 sr powered coupe,06 Spec V
just wondering if the speedo is accurate after the sr swap....just got mine done..i did get a front clip and put the tach in...so thats ok...but the speedo is from the ka....and i didnt put the ka speed sensor in either???...so is it in kiolmeters?..cause i pin it at 115 in no time....but i kno im goin faster than 70...whats the deal...thanks
lee_harvey
Car: 93 nissan 240sr
mine is 2mph fast. as in i'm going 68 but speedo reads 70. but the tach is off about 3-4 hundred.
boost_creep
hmmm...2-3 mph huh.....thats odd....thanks man...how come the tach is off though.....i put in the jdm....did u?...is the tach ahead 300 or behind?
SR20DETPoweredS14
Car: 1999.5 Audi A4 1.8T
I beleive if you put in the JDM Cluster that came with the front clip you should be fine and it should be rather accurate.
SR20DETPoweredS14
But considering you dident put the KA speed sensor i think it will be a bit off
boost_creep
well i didnt put the jdm cluster in....just the tach..along with the sr speed sensor...does this change things?
SpeedRacer1
Car: 1990 240SX, G35
89 240hatch wrote:well i didnt put the jdm cluster in....just the tach..along with the sr speed sensor...does this change things?
Thats my setup. Runs fine, reads speed right, reads tach right.
RMiller
Car: BBQing
How do you know the engine speed is off? If it's a turbo timer, or any other signal, you might as well take the average of the 2 to get a closer reading.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i ran with a USDM tach for almost a year and had no problems with it reading off. Also, as long as you swap in the KA speed sensor, you should read fine. If you keep the SR speed sensor, it will be off a marginal percentage.
SpeedRacer1
RMiller wrote:How do you know the engine speed is off? If it's a turbo timer, or any other signal, you might as well take the average of the 2 to get a closer reading.
I know mine is accurate via an SAFC2.
boost_creep
thanks guys..
