stock sohc fuel rail and injector?'s
Lroi
Car: 1990 240sx
should there be some kind of clips holding the injectors to the rail on a stock 90 s13 sohc 24ke?
what should I look for if one of the nozzels on a injector is cracked? (cause)
if anyone cares the part# for injector o-ring kit is 2-12076 (napa) its like 4.50$ for 1 injector and has all three rings needed for the injector.
I had quite a time with advance and auto zone, 1 shot w/napa
I'm still waiting on my book thats why I posted!
Import_Ant
thanks for the O-Ring part number I'm about to start rebuilding one that'll come in handy. I am not sure about your other questions but if your injectors are leaking it's likely the cause is a bad oring(s) I'll snap a pic of my spare SOHC motor I have on a stand tonight to show you how the fuel rail and injectors sit if that will help you any. I dont believe there is a clip holding the injectors TO the rail though I believe they're just pressed in when you bolt the fuel rail to the intake manifold.
Lroi
Car: 1990 240sx
thanks, this is my first import ever! and it freaked me out when I just pulled the injectors out of the rail. cant wait to see the pics
