Stock Side mount intercooler + USDM bumper = ??
CRyan
Car: 1997 Nissan 240SX
Hey guys - Just finalized everything with the S14 SR for my 97, and I figured while it was on my mind I would ask really quick a few questions.
Firstly, How does the SMIC mount in the USDM front bumper fit? Pictures would be great.
Secondly, what about stock piping? Will there be cutting involved? Its no biggie but I'd just like to know what will need to be done so I can go ahead and do it while old KA is out
Luckily I have a great g/f that will be willing to help clean out the engine bay, etc.
But any advice will be greatly appreciated
Thanks
CRyan
mRodiek
Car: Stock Hatch
It should bolt up to where the stock airbox used to be, at least its like that on the S13s
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Yeah, that's where it bolted up on my S13 so yours should be similiar. The only thing I had to mod was the stock intercooler ducting. I had to shave about an inch off because I had the non-turbo bumper which doesn't protrude out quite as far as the turbo bumper. Looking at how far the bumper on the lower portion of the USDM bumper goes out you shouldn't have any fitment problems with the ducting if you choose to use it.
CRyan
Thats what I needed to know guys! Started removing ka last night for the SR that should me in next wednesday Im super excited to begin with the project super stock!!
Tulsa_S-13
Car: 1991 SR 240sx
positron_ wrote:Yeah, that's where it bolted up on my S13 so yours should be similiar. The only thing I had to mod was the stock intercooler ducting. I had to shave about an inch off because I had the non-turbo bumper which doesn't protrude out quite as far as the turbo bumper.
That's odd. When I was using the SMIC with the stock ducting I didn't have any problem at all with fitment. That was while using the correct mounting tabs and everything.
On the S13 there is an indention where the stock SMIC piping runs through. I'm not sure if the S14 is like that or not. Unless you have a hole saw, you can draw out where the hole needs to be and drill several small holes along the outline. You should then be able to use a mallet and punch through it.
You need to take use something around your new hole so you don't end up with a hole in your piping. I ended up taking a piece of hose, cutting a slit along it and placing it around the edge of the hole. Hope that makes sense.
positron1
That's exactly what I did too on the hole drilling and lining. As far as the ducting went, everything fit and lined up where it was supposed to. Only I had to remove the vented cover off the lower section of the non-turbo bumper because the intercooler ducting was protruding out so in order to make it look stock I shaved a inch off the ducting allowing me to put that vent cover back on.
