TachyonS14 »
https://forums.nicoclub.com/tachyons14-u10260.html
Fri Nov 14, 2003 6:48 pm
LiU I know exactly what you mean. You try to tighten It as far as It can but It will not line up correctly. So, what I did Is I went out and bought some thread lock, you should be able to find It like at home depot. Anyways, you apply some of that on the threading on the shifter and screw It Into place where you want It, and let It dry over night and It should be fine. And If you want to take your knob off, just give It a little twist and the thread locking material will break loose.
