crzycav86 wrote:se rims won't clear the 30mm calipers, period.
there is one type of SE rims that'll clear the 26mm calipers. behind the spokes, if the metal curves, it won't clear.. that's the type that won't clear. they other type - behind the spokes is flatter, and it will clear. there was a thread on this a couple years ago. try searching 26mm and spokes. that is if you're using the 26mm ones.
Well i was going to run 30mm but im guess im going to have to plan to use the 26mm. For right now im planning on only doing the front calibers and rotors. Ill check my wheels later today and get my verdict. Also is there a stoping power diffrence with 26mm and 30mm? Just to get my facts straight.
