Still an option on the base. That and the tires on my SE when I bought it where 195s. That could have been the previous owner, or a not so savvy shop.SeVa-S13 wrote:SE is 205, base is 195.
You shouldn't have any difference in speedometer reading with either of those size tires. The first number is width, not sidewall. 205s shouldn't rub at all either, I had them on my first 240sx.H8tred wrote:Tire rack tells you factory tire sizes, and options...
Original Equipment is 195/60-15
Optional Equipment is 205/60-15
I have the later and get rub on left hand full lock turns.
Also, my speedometer should be reading 2% slower. Meaning that when it says I'm going 60 mph, I should really be doing 61.2 mph...
They width actually changes the outside diameter. Not by much, and that's also assuming that the oem speedo is 100% accurate.lbrowne wrote:
edit: to the original poster - I've ran both 205s and 195s on my 240 and there isn't much difference between the 2 other than 205s are a bit better in the turns due to a wider foot print - but I don't think you'll notice if they were the same type/model/manufacturer of tire. It's really not worth a debate, the narrower 195s could possibly fare a bit better in the snow as narrower tires do.
Absolute first time I've ever heard of that. My TA had 245 stock and I've gone to a 275 on a larger rim with no change whatsoever on the speedo.H8tred wrote:
Wider is better for initial launch traction to an extent and for cornering/high speed turns, obviously in optimum onditions. Wider is not better in the snow, is not better in heavy rain fall against hydroplaning. Theres pros and cons to tire sizes, saying wider is better is not always a valid comment.Fr0zEn wrote:The door says Front 195/60/R15, Rear 205/60/R15
I want to go with 195/60R15 Front (New tires on front already) and 215/60R15 on Rear if they fit. if not 205/60R15 works.
and Yes the Wider the Better.
