Stock s13 MAFS?
Cyt0teC
How much air (boost) can the stock s13 MAFS measure before 5v cutoff?
Also,
What happens at 5v?
Do the injectors stay wide open? or is there a fuel cut?
themadscientist
as i understand it once the air flow meter reaches it's max it can't tell the computer that more air than that is coming in so the injector duty doesn't increase as it should. You go lean with all the expensive results. You might want to look into the 300ZX flow meter swap.
Cyt0teC
^^Bump^^
Anyone know the answer?
