92droptop »
https://forums.nicoclub.com/92droptop-u31754.html
Tue Apr 25, 2006 5:53 pm
Out of curiosity, why would it be necessary to replace the OEM pump when using a mild setup (T25, SR intercooler, 370cc injectors, etc.) at stock-7psi-boost? The pump is able to handle the needs of the SR, why would it be so different on the KA? Note I am speaking of necessity, not prudence, per se. I know that it would be prudent to change the fuel pump, but necessary for that setup? I just don't see it. The people on that setup are typically the ones who can't afford a whole lot. (I know, gotta pay to play.)
Now, for power goals any higher than the very mild KA-t build just mentioned, I agree that an upgraded pump is absolutely necessary. If you can afford the $1200+ for that setup, then you had freaking better be able to fork over another $90.
Please don't flame me for this post, I may not have many posts here, but I'm no newb to cars or engines (or forums for that matter). Quite to the contrary, I am just finishing my degree in Mechanical Engineering. I am just looking for educated answers. If there is a legitimate reason for the necessity of the Walbro pump at meager power levels, then I will be the first to accept it. Personally, I am building for somewhat higher power levels, so the Walbro was actually my first purchase. Sorry for the length.
