Stock rubber tube between compressor and maf? and plumbing?
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Well im bored, im moving soon so im not gonna start any big motor projects. till i get a ****ing garage haha, has anyone replaced the rubber pipe between the maf and compressor, with something that looks like it "flows" better? any pics?, i extended my maf wires last night and am running the tube straight so the filter is up against the fans/radiator, probobly going to replace the pipe with somthing, also has anyone got rid of all those damn pipes that go along with the bov etc.?
yes im board
Joe
ive thought about replacing that intake tube with something less turbulant but have never gotten around to it.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
I've got a few mandrel bends laying aroud, i'll probably get a pipe made a get a nipple or two welded onto it so i can recirc the BOV and the Crank case if i decided to take off my Catch can.
I could do a write up and send it to you over aim.
RB20DETodd
nice, im gonna order a 2''-3'' coupler tomarrow and get a random peice of pipe, and mess around, im wondering if i can get rid of all te bov tubing with flexible hose, and clean it up a bit.
Wulfgang
I thought you were working on A/C? There is no room for the filter in front of the compressor is you use A/C (i.e. you have to use the stock coupler).
Also, I don't think a mandrel bend will do it. You need both a bend and an expansion in a very short space, which would be much harder to come by. You could mold the bend out of cf, tho.
Of course if you don't have that A/C compressor and hoses in the way, then there's a lot more room to do interesting stuff.
RB20DETodd
Wulfgang wrote:I thought you were working on A/C? There is no room for the filter in front of the compressor is you use A/C (i.e. you have to use the stock coupler).
HAha, yeah a/c is done BUT went to charge it and found that the line off the reciver dryer closest to the firewall has a hole in it damnit!, and i no more the powersteering pump so i have lots of room.
