Stock rods on Aftermartket pistons???
driftneil
Car: A pile of cars.
Is it ok to run the stock SR rods on a Aftermarket piston?
Also, does anyone know what the stock SR rods will max out hp wise?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Yes you can run stock rods with aftermarket pistons, thr wrist pins are the exact same size. there has been a couple stock bottom end cars running 600 hp. If your going to max them out, id get them shot peened, and maybe even cryo treated and they will be able to take a beating. (stock rods can take a bearing anyways)
driftneil
Nice thanks, I was a little over 4oohp. And I snapped a spring and threw a rocker arm, and dropped a valve onto the piston.
But if I would get the rods kryo'ed and peened I might as well just get new rods.
compactfean
daily
400 hp is easy peasy on stock rods. Id do it.
driftneil
Well I was holding off on upping the boost, I was only at 16lbs on a gt30. I can max out at 32. And since I'm rebuilding the head anyway with better parts, I was going to up the boost. Expecting around 550.
